Oracle® Insurance Rules Palette
When OIPA encounters a RATE or RATEARRAY math variable type, it executes one of three access methods. Accessing rates through an extension framework is one of those retrieval methods. The property rateRetriever.className allows an extension to access rates. The property identifies the extension by its fully qualified class name. OIPA passes parameter information to the designated extension. The extension may return one rate or multiple rates as a result of the RateGroup's structure and the parameters provided by the RATE or RATEARRAY math variables. If the appropriate result is not returned, an exception will be thrown.
Refer to the 10.1.0.0 Documentation library on OTN for a complete explanation of this property.
Modifications to the System Properties file requires a restart of the application.
RATE and RATEARRAY can be used with stored procedures and/or extension framework.
If a class name does not exist when OIPA attempts to process rates, then an error will be logged and processing will continue using the default method.
If a bad parameter is passed, then an exception will be generated.
Copyright © 2009, 2014, Oracle and/or its affiliates. All rights reserved. Legal Notices
